Limiting Config management to a group, inventory for all devices
miheg
Level 5
Level 5
Is there a "Clean" way to tell ciscoworks to do config management only on a group of devices?
I want ciscoworks to do inventory and syslog on all discovered devices.
But config management only on a group.
If this is possible, how can I achieve this?
Cheers,
Michel
b.hsu
Level 5
Level 5
The Archive Management application maintains an active archive of the configuration of devices managed by RME. Check out the following link for more information :
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_user_guide_chapter09186a008032744f.html#wp1063851
I think you didn't see my point.
There are devices for which I don't have the right access right to do config management.
I do have enough access the to do inventory and since I receive syslog and traps the "readonly" apps are happy.
RME completely ignores the absense of a write community string and passwords and simple scream error, and by doing so hides real problems with devices the I wish to do config management on.
If I could limit config management to a group this would resolve my issue.
Michel
