line console issue
mohammed taha moussa
Community Member
I was working on cisco 1841 router and suddenly I can't have output from the line con 0 on my monitor , I had connection to the router with telnet and ssh
but I've erased the config thinking that it would solve the problem but insted I'm locked out the device I can have access to another device with the same console connection so the cables won't be the problem, the only thing that shows me when the router reboot and when an interface change the status
6 Replies 6
Sandeep Choudhary
HI Mohammed,
Please first check cable.
Check the Com port again.
still issue persists thenI tthink  config register value issue, the console port speed has been changed.
Try multiple speed settings:t 2400 baud ,then 4800 , 9600 , 19200, 38400,  and 115200
Try and check if you get any response .
If you finally get a response change the config register setting to either 0x2101 or 0x2102 .
Dont forget to rate helpful posts.
hi sandeep
I've tried to change the speed as you said but I still have the same issue I've tried different cable and nothing
I tried to connect to another device and I had access with the same cable.
HI Mohammed,
After connecting with console cable.....
did u see any kind of output on screen or its totally empty??
It shows me the output of the boot process and when an interface change
The status but that's it it won't gave me any other output nor let me tab
Any thing
Which terminal emulator u r using : hyper terminal or teraterm or putty.
Please try to change and try again.
Don't forget to helpful posts.
I'm using putty but I've tried hyper terminal and it's the same
from the 4 devices that have that issue I can access one device so I did show line con 0 to see where in the
difference and the output was the following
SW1#sh line con 0
      Tty   Typ     Tx/Rx    A   Modem  Roty   AccO  AccI   Uses   Noise  Overruns   Int
*      0    CTY                 -       -          -           -        -          2       6          0/0         -
SW2#sh line con 0
*    0     CTY                  -        -          -         -          -         0       1          0/0         -
SW1 is the device with the line con problem
SW2 is working just fine
