LMS 2.5.1 & ACS 4.0 Java
mbaylis
LMS 2.5.1 and ACS 4.0 both use different versions of Java, meaning that as network admin, I cannot get onto both systems from 1 machine.
Any ideas on a Java version usable by both ?
1.4.2_10 for CW LMS & 1.4.2_04 for ACS
Thanks in advance
Martin Ermel
try the following:
in the java admin panel (control panel - java plugin)
clear the java cache
remove the integration from your browser
install the latest java version from the 1.5 release from SUN and integrate this with the browser
Install any Java version you need, but do not integrate it with the browser.
clear the browsers cache and delete the cookies
close any open browser session
open your browser and try to access LMS
try to access topologyservices
If that works close any browser window and try to access ACS.
I do not know if you can have concurrent browser sessions for both LMS and ACS but it should work if you access these apps one after the other.
Java 1.5 should handle a redirection to the java version required by the web page (and available/installed on the system) without any changes to the browser integration.
MArtin
Martin Ermel
try the following:
MArtin
Excellent - all fixed
Many thanks
