LMS 2.5 2005 Update Installation Error
salman-ahmad
I am trying to install the evaluation version of LMS 2.5 in our lab for one of our customer.But when i trying to install i have found the attached LMS2.5.jpg error. The specification of system in which i installed is the following.
    • Microsoft Windows 2000 withService Pack 4.
    • 2 GB RAM.
    • Disk Space: Total:72.4 GB, Free Space:22.0GB, Used Space:50.3GB
    • IIS & terminal serrvices were also disable.
    • Java Run Time JRE latest 1.5 also check with 1.6.
Do let me what and where i am missing some thing due to which i am unable to start installation.
Thanks & Regards,
Salman Ahmed
Thomas Masters
LMS 2.5 December update is a bundled patch for LMS 2.5 , you would need the base product first.  LMS 2.5 product has been EOL since March 2010.  You may want to evalute the more recent version Cisco Prime LMS 4.1 available for download at http://www.cisco.com/go/lms
Thomas Masters
Thanks,Thomas for such a reliable infomation.Kindly, also tell me some more information for the same following:
  • Cisco Works LMS 2.6,3.0 or earlier 3.2
KInd Regards,
Salman Ahmed
LMS 2.6 - eol
LMS 3.x - eol Nov 2012,
LMS 3.2 - end of sales Apr 2011, end of support Nov 2014
So you would need to purchase LMS 4 at this point.
