LMS 2.5 - Deploy failed
mnewnam01
What I am attempting to do: create a task that will copy the start config to the running config on 2950G-48 EI.
What I did:
Created a User-defined task with the following commands(command mode=Enable):
copy start run<cr>
running-config<cr>
Created job, ran immediately.
LMS response:
Failure - Command(s) failed on the device. Insufficient number of interactive responses for command: copy start run. (comments about TFTP and SSH)...Cause: Device is Unreachable (this is not true)
I created another task in config mode that executed properly. I think the interactive nature of the copy command is causing the problem. Anyone encountered this?
nhabib
Level 9
Level 9
nhabib
Level 9
Level 9
I haven't tried this myself, but the User Guide says to use for interactive commands:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/4_0/u_guide/netcfg.htm#wp1301559
Thanks! That reference worked. Use preceeding an interactive reply.
