LMS 2.5 Shadow directory
lgille
How does the shadow directory work? I have noticed that old device files is never deleted in the shadow directory, if I delete all files
they don´t appear until the configuration is changed on the device.I want the shadow directory to match the managed devices.
5 Replies 5
nhabib
Level 9
Level 9
The shadow directory is supposed to hold the most recent archived config of the managed devices in RME
If a device is removed from RME, its config will remain in the shadow directory
Keyan
Where is the shadow directory in LMS 2.5? I can't find it on my install.
It is disabled by default
To enable it, go to RME -> Admin -> Config Mgmt -> Archive Mgmt
I enabled it but still can't find it..what is the path? Do I need to restart the server?
next time the archive is updated, the config files will be there
