LMS 2.5 SWIM issue
leeeplus
Im having a problem with software distribution on LMS 2.5. The distribution job always come back as "failed". But when i look at the device the image was successfully delivered. ANyone have insight into this?
craig5571
check your transport protocol, its probably set for tftp, and thats what is successful the tftp transfer. change it to telnet and you should be fine and it should accurately report the status of the job. what was "successful" was the tftp transfer and with tftp there is no way to check on the status of the job once the transfer was complete
leeeplus
Telnet is not an option under the SWIM transport protocols. TFTP, RCP, SCP, and HTTP are the only choices.
