02-17-2005 04:59 AM
Having just downloaded the new updates posted for Ciscoworks, DFM now no longers works using the new Java. I get a screen and looking at the Java console it looks like it is workins however, the window never gets populated with anything. Am i doing something wrong or is this really broken and waiting for a fix? Help.
Thanks.
02-17-2005 07:43 AM
Have you checked your classpath environment variable. Looks like your maybe not picking up some critical classes which are probably in .jar files.
The JVM should indicate if this is the case.
02-20-2005 08:53 AM
Thank you for your reply.
How would I check this? What would I do to fix it?
Thanks.
02-18-2005 12:30 AM
I had the same pb. I go back to java 1.4.1_02 and it's ok now.
to do it, you must remove 3 files manualy on W2K :
search for the files :
connectEntryJSP1.pl and connectEntryJSP1.pl-CSCsa45555-1
remove connectEntryJSP1.pl and rename connectEntryJSP1.pl-CSCsa45555-1 to connectEntryJSP1.pl
do the same with :
javaplugin.properties-CSCsa45555-1
and last remove the file /setup/patch/CSCsa45555-1.info
You can found java 1.4.1_02 here on the ciscoworks server
02-18-2005 12:37 AM
JRE are not backward compatible.
So you have to use the JRE 1.4.1_02 with ciscoworks.
02-24-2005 04:10 AM
This is a known bug (ID CSCSa492327) and a patch is available from TAC to solve the "DFM not launching after installing JRE 1.4.2_06 patch). In my case it works fine (and I can use the integration with HPOV NNM which need 1.4.2_06 too)
02-24-2005 04:43 AM
Thank you for your help but I am unable to pull any info on that bug ID. Do you have a link to the patch?
Thanks again.
02-24-2005 06:08 AM
I think you have to open a tac case to get this fix. I told the TAC engineer that I couldn't find the bug either. The bug only replaces an existing jar file (named dfm-sign-1-4 located in ~CSCOpx\www\classpath)
02-24-2005 06:19 AM
When trying to open DFM I opened the java console and saw something about that file(dfm-sign-1-4) coming up over and over. It also pointed to the same location you mentioned.
This is good info.
Thank you very much for you help.
02-24-2005 09:31 AM
I got the pacth after opening a TAC case and DFM is now working. I unerstand that Cisco is working on a patch for the masses.
You've been a great help.
Thank you very much.
02-24-2005 04:11 AM
07-19-2005 10:41 PM
Hi , I desperatelty need this patch for an install I'm doing - can you tell me where I can get it. After installing cmf2.2.2-sol-CSCsa455551-R3 my DFM does'n not display anything anymore. I'm running LMS 2.2, DFM1.2 with IDU 10. Thanks
07-20-2005 09:23 AM
Open a TAC case and mention that you need the DFM patch that goes along with CSCsa45555
