Has anyone else had difficulty with Campus manager topology map not showing links between switches? The first step, CM device discovery list each of the switches as being neighbours, but when I run the second step, CM data collect these switches are listed without neighbours.
CDP is fine as well as SNMP. Logs dont seem to helpful.
If anyone else has a similiar problem can you list your hardware\link config. I have a problem with 6509 linked to Catalyst 3750G-12S over redundant layer 3 etherchannels.
