LMS 2.5 user authentication problem
joshmwoody
Set up Works to run in ACS mode. Created user account on ACS. Created user account on works and assigned SA and NA roles. I can log in successfully and verified access permissions from Who is logged in Report. The problem is when I try to access certain application features eg Device Management Summary in RME I get the following error
You are not authorized to request the Action associated with screenID: "/deviceSummary".
Any ideas of where to look next appreciated
David Stanford
It looks like you might have missed the steps in ACS to add the LMS modules.
ON ACS
* Step 7: Add "SUPERUSER" role for each module of Ciscoworks in ACS
-Go to SHARED PROFILE COMPONENTS
-Select a CW module (such as Common Services)
-ADD
-Name it CWSuperUser or something similar
-Select everything under the available functionality for that module
--REPEAT above procedure for Ciscoview, RME, Campus, DFM and any other Ciscoworks modules
such as IPM, etc.
* Step 8: Assign the "SUPERUSER" role to the Admins Group (created in Step 3)
-Go to GROUP SETUP
-Edit Settings
- Select cwhp, rme, campus, dfm and any other CW components a select the "SUPERUSER" role
(created in step 7)
-Submit+Restart
David Stanford
ON ACS
-ADD
such as IPM, etc.
-Go to GROUP SETUP
-Edit Settings
(created in step 7)
-Submit+Restart
not sure where those steps are documented, but that worked for me.
