If you don't have Switch probes or Network Analysis modules in these switches then you will only get miniRMON in nGenius RTM.
This will give you some basic stats, but if you are looking for something like application layer conversations, data capture, etc (higher level info) then you will need to pull data from the NAM or probe.
