01-08-2009 01:16 AM
He ALL,
I got a error message when I work with IE 7.0 likely
TransformerException:
javax.xml.transform
The markup in the document following the root element must be well-formed
Does someone know about this ?
Danke Gruss Steffen
Solved! Go to Solution.
01-28-2009 08:40 AM
Yes. LMS 3.x supports IE 6.0, 7.0, and Firefox 2.x.
01-08-2009 07:10 AM
Where exactly do you see this? What are you doing in LMS?
01-27-2009 02:36 AM
He JClarke,
I simply will open the web interface with MS 7.0 to LMS and got the unsupported IE version error.
Gruss Steffen
01-27-2009 02:33 AM
He Again,
does someone know how LMS 2.6 can working with MS IE 7.0, as I still got the error of unsupported IE version.
Danke Gruss Steffen
01-27-2009 09:39 AM
I missed the LMS 2.6 part. No, IE 7.0 is not supported in LMS 2.6. You will need to use IE 6.0 or Mozilla 1.7.
01-27-2009 10:21 PM
He JClarke,
danke.
Based that the company PC's has a automated MS update policy, the customer can't change the explorer back to IE 6.0 or other one. In this case there is a need that LMS 2.6 support IE 7.0
Gruss Steffen
01-27-2009 10:53 PM
This is not going to happen. We are not certifying any new browser support for LMS 2.6.
01-28-2009 12:24 AM
He JClarke,
danke.
Does LMS 3.x support IE 7.0 ?
Gruss Steffen
01-28-2009 08:40 AM
01-28-2009 10:14 PM
He JClarke,
danke, cool
Gruss Steffen
