10-18-2007 05:28 PM
My Ciscoworks server install on Solaris 9, and tftp already run, but I cannot using RME to maintain the IOS image. I tried to copy the image by command but the following error appears.
R10k8-HBT-BRAS05#copy disk0:c10k3-eboot-mz.122-31.SB5.bin tftp:
Address or name of remote host []? 192.168.2.5
Destination filename [c10k3-eboot-mz.122-31.SB5.bin]?
TFTP: error code 1 received - 18025
%Error opening tftp://192.168.2.5/c10k3-eboot-mz.122-31.SB5.bin (No such file or directory)
bash-2.05# ./mping -s tftp nms
sent: 5 recvd: 5 min: 2 max: 3 avg: 2 timeout: 2 size: 25 protocol: tftp port: 69
bash-2.05#
Brian
10-19-2007 07:35 AM
Did you create an empty "c10k3-eboot-mz.122-31.SB5.bin" file on the tftp server (in /tftpboot typically) before you started the CLI tftp? That's how tftp works.
So going by that thought, does your CiscoWorks have write access to your tftp root directory, whatever you designated it to be in CiscoWorks?
10-21-2007 08:39 PM
