LMS 2.6 Integration in NV AIX 5.3
Tobias Heisele
How do I integrate LMS 2.6 running on Win2K3 into NetView 7.1.4 running on AIX 5.3? Are there somewhere new adapters for AIX?
David Stanford
Go to this link:
http://www.cisco.com/kobayashi/sw-center/cw2000/cmc3rd.shtml
This will have the integration util for LMS and Netview 7.1.x, please make sure to look at the readme for instructions.
Thank you, but I can only find an adapter f?r AIX 5.1. Will it work on AIX 5.3 aswell?
From looking at the readme on the adapter I just see that it will support AIX 4.3.3 or later
yes, but the adaper is made for LMS 2.2 with CiscoView 5.5. Has somebody a working ciscoaction.xml file?
