LMS 2.6 RME Software Distribution by device
dschultz307
I thought I could do this in LMS 2.5 but 2.6 Software distribution basic do not have the CS@server option to select devices to upgrade by type or model.
Example: I want to select and upgrade all my 2950 switches in one job.
Thanks for any ideas.
Dave
Joe Clarke
Make sure you device type group is enabled under Common Services > Device and Credentials > Device Selector Settings > Group Customization.
This is a new feature of LMS 2.6 which is designed to make the device selector more powerful and less cluttered. However, all of the functionality from 2.5 is still available.
YES!
It worked!
Thank you very much!
