LMS 2.6 - SSH Connection Failed
agipkcolon
Dear All,
I have LMS2.6, RME4.0.6 on W2003
Currently faced problem with SSH.
Something about 50 devices out of 300 are failed to connect by SSH (Device Credential Check and ArchiveSync)
I checked credentials and I can succeffully login to problem device by SSH(v1&2) from CW Server with SecureCRT.
I tried to remove and add again problem device - doesn't help.
I enabled debugging for ArchiveMgmt Service and attached dcmaservice.log for sync archive operation of one of the problem devices.
Can you please tell me what's wrong?
Joe Clarke
This looks a lot like CSCsl52476 which is fixed in the RME 4.0.6 that is posted on Cisco.com now. When was RME 4.0.6 downloaded from Cisco.com? You might try re-downloading it from http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme , and reinstalling it.
