LMS 2.6: /var/adm/CSCOpx/files/rme/dcma/difffiles directory too big
leorob123
Hi folks!
The difffiles directory, after purge the old config files, increase its size continuosly.
So, how I can reduce its size?
Leonardo
Joe Clarke
You are seeing CSCse88215. The workaround is to manually delete the contents of the difffiles directory. They will be recreated as needed.
Joe Clarke
