LMS 2.6 Which active device should be seed device?
ohalnet53
Hi mates :)
I need some ideas please...
please see attached "seed_device.jpg" file. This figure shows my overall network diagram.
My question is: According to the figure, which active device should I use as seed device when I configure seed device on LMS 2.6? If you think I should assign more than one seed device, please advice me which ones?
I'll appreciate any help,
thanks in advance :)
Joe Clarke
Given the number of connections, switches I and J would be good seed devices.
thanks pal
