LMS 3.0.1 + ACSv4.2
punit.dixit
I want to know,when integrating LMS with ACS, if all devices are necessary to bind with TACACS+ (ACS) or just adding a NDG with ip range is possible or any other ? because i want to create diff. admins for diff. NDG.It will be cumbersome task to bind each & every device with TACACS+ now. How to proceed ?
Joe Clarke
You can use IP ranges within NDGs, and LMS will be able to manage all devices in those ranges. You do NOT have to make the devices themselves actually use AAA.
Thanks for your reply.
