LMS 3.0.1 SNMP working.
laerciotobias
Hi all.
After i upgraded my MDF to 1.50 the SNMP is not working.
I alread applied the fix to bug CSCsl00042-0 but still not working.
The SO is solaris 9.
Follow the package details.
1. CiscoWorks Common Services 3.1.1
2. CiscoView 6.1.7
3.  LMS Portal 1.0.1
4.  CiscoWorks Assistant 1.0.1
5 Resource Manager Essentials 4.1.1
root@AL-GR-SV-RL # cd /opt/CSCOpx/bin/
root@AL-GR-SV-RL # ls -lh
-rw-r--r--   1 root     other       7.3K May 27 17:09 CSCsl00042-0.pl
Thank you.
There are many bug fixes even in moving from 3.0.1 to 3.1.  Any 3.x release can be upgraded in-line.  However, I suggest performing a full backup just in case.
Nick
5 Replies 5
ngoldwat
Level 4
Level 4
First, how did you determine that your issue required the above patch?  Have you considered upgrading to LMS 3.2?
Are the following packages installed on your server?
• gcc 3.4.6
• net-snmp 5.1.1
• openssl 0.9.8e.
The reason i upgraded the server from 3.0 to 3.0.1 was the need to install CV and rme device packages for the newest devices on my network.
Is there any way to install 3.2 without a fresh installation? if so that solve my problem
Nick
Hi thanks for the update,
could you please pass the download link for the upgrade version 3.1 ?
also is that possible upgrade from 3.0.1 to 3.2 ? or the only way is 3.0.1 to 3.2 ?
Thank you.
