LMS 3.1 and 3750E-48PD Inventory
krhashbarger
I am having a problem with LMS 3.1 I have added a 3750E-48PD switch to LMS 3.1. It discovered it fine and has archived the config, but when it does an inventory it fails. I have deleted the device from RME and re-added it. I have also deleted it from both RME and Common Services and still that is not working. It downlods the config, but fails on the inventory. The SNMP statements are correct and login information is correct.
5 Replies 5
MICHEL.HEGERAAT
Are you able to do an snmpwalk from ciscoworks device center?
What IOS are you running on it? 12.2(35.1)SE or higher is required on the device.
Cheers,
Michel
I am running Version 12.2(46)SE
David Stanford
What error message are you seeing?
Can you enable debugs for ICServer and then have a look in the IC_Server.log for this device and related messages?
Can you tell me where I would enable Debugs for the ICServer?
I also discovered after the inventory job as run for several hours, it shows up as being canceled. I never canceled it. There is nothing in the log file for that device at all.
