LMS 3.1 DFM polling configuration/monitoring
lucky.sibanyoni
is it possible to get notifications on port channel utilization but not on the physical member interface? i have a problem here: some of the interfaces i'm monitoring using DFM are member of the port channel, and i want only to monitor utilization on those particular devices for Port channel not the actual physical interface.
or is it possible to exclude device interfaces from being monitored? if yes, how do i go about doing that. if not, what other option are available to achieve this?
Joe Clarke
Sure. Just go to DFM > Device Management > Device Details, and set the desired ports' management state to false. Then, DFM will not generate any events for those ports while still monitor the channel ports.
