is it possible to get notifications on port channel utilization but not on the physical member interface? i have a problem here: some of the interfaces i'm monitoring using DFM are member of the port channel, and i want only to monitor utilization on those particular devices for Port channel not the actual physical interface.
or is it possible to exclude device interfaces from being monitored? if yes, how do i go about doing that. if not, what other option are available to achieve this?
