LMS 3.1 DFM pooling error
I have LMS version 3.1 installed at one of my site. we are monitoring 96 routers and switches using it. few switches are 6509 switches. before 3 days a outage occured due to high temperature with one 6509 switch, how ever we didnot got any alert for that activity. even there is no event record in fault hostory for "statenot normal".
I was trying with packet capture but found no snmp get request for the device with below OID
1) 1.3.6.1.4.1.9.9.13.1.3.1.3
2) 1.3.6.1.4.1.9.9.13.1.3.1.6
3) 1.3.6.1.4.1.9.9.13.1.3.1.4
How ever the capture contains pooling of other devices with these OID. I have attached the capture here with. Ip address of the 6509 switch is 10.124.133.2
Below mentioned the output of the show env status of the switch. Please help me to understand why the pooling of envirnoment related variables are not hapenning.
6509-1_Delhi#sh environment status
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6509-E-FAN
  fan-tray 1 mode: Restricted-power
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 29C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 33C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 35C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: DC low
  power-supply 1 power-output-mode: low
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: DC low
  power-supply 2 power-output-mode: low
  power-supply 2 power-output-fail: OK
module 1:
  module 1 power-output-fail: OK
  module 1 outlet temperature: 56C
  module 1 inlet temperature: 33C
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 40C
  module 2 inlet temperature: 33C
  module 2 device-1 temperature: 32C
  module 2 device-2 temperature: 38C
module 3:
  module 3 power-output-fail: OK
  module 3 outlet temperature: 45C
  module 3 inlet temperature: 36C
module 4:
  module 4 power-output-fail: OK
  module 4 outlet temperature: 48C
  module 4 inlet temperature: 35C
  module 4 EARL outlet temperature: 37C
  module 4 EARL inlet temperature: 39C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 32C
  module 5 inlet temperature: 23C
  module 5 device-1 temperature: 37C
  module 5 device-2 temperature: 38C
  module 5 asic-1 temperature: 21C
  module 5 asic-2 temperature: 21C
  module 5 asic-3 temperature: 21C
  module 5 asic-4 temperature: 21C
  module 5 asic-5 temperature: 21C
  module 5 asic-6 temperature: 21C
  module 5 RP outlet temperature: 26C
  module 5 RP inlet temperature: 29C
  module 5 EARL outlet temperature: 36C
  module 5 EARL inlet temperature: 29C
module 6:
  module 6 power-output-fail: OK
  module 6 outlet temperature: 48C
  module 6 inlet temperature: 26C
  module 6 device-1 temperature: 27C
  module 6 device-2 temperature: 44C
module 7:
  module 7 power-output-fail: OK
  module 7 outlet temperature: 43C
  module 7 inlet temperature: 25C
6509-1_Delhi#sh environment temperature all
  module 2 device-2 temperature: 37C
  module 3 outlet temperature: 44C
  module 3 inlet temperature: 35C
any help?
