Netflow problem
btaillan85
Frequent Visitor
Frequent Visitor
I have a cisco 3845 with netflow V5 and I have problem netflow packets are sent to process level.
  Export source and destination details :
  VRF ID : Default
    Source(1)       X.X.X.X
     Destination(1)  Y.Y.Y.Y (9997)
  Version 5 flow records
  474561521 flows exported in 15818912 udp datagrams
  0 flows failed due to lack of export packet
15817049 export packets were sent up to process level
Cef is activated
Netflow packets are not sent to the collector or too late
When I activate debug ip flow export:, I have this:  Error sending export packet: Enqueued to process level
My ios version is (C3845-ADVIPSERVICESK9-M), Version 12.4(9)T7,
Have you got an idea to prevent packets to pass in process level .
Don Jacob
Level 7
Level 7
As per Cisco, packets sent to process level signifies the packets not processed by CEF or switching. Could be packets not switched?
0 export packets were sent up to process level
The packet could not be processed by CEF or by fast switching, possibly because another feature requires running on the packet.
http://www.cisco.com/en/US/docs/ios/12_2/switch/command/reference/xrfscmd5.html#wp1071616
Don Thomas Jacob
ManageEngine NetFlow Analyzer
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
