You are most likely seeing one of three possible bugs:
CSCsx24218
CSCsv95235
CSCsw88378
A patch for all three is available by contacting the TAC. As for getting rid of this job, if you run pdshow, and you see a daemon corresponding to the job ID, run:
pdterm ID
For example:
pdterm 1101
That should stop the job. If that doesn't work, you will need to get the instructions from TAC to purge the job from the database.
