LMS 3.1 - Saving Reports in RME
mwynen
Hy.
After generating a "Detailed Device Report" I want to save the reports as a CSV. But everytime I only get a file named "InventoryReports.do" that contains only a header, but no other informations. In LMS 2.6 this file was normally called "export.csv" and contained all informations of the report. What is going wrong and how can I fix this?
Thanks in advance!
cheers
Marc
Joe Clarke
I just tested this with Firefox 2.0.0.21, and I get an export.csv by clicking on the export icon. The report contents are what I expect them to be. What browser are you using? How are you performing the export?
Hy.
I'm using IE8. But after you told me it's working with Firefox i tried it with IE6. This is working. So it seems that LMS3.1 can't be handled corectly using IE8.
Thanks for your help!
cheers
Marc
IE 8.0 is not supported yet.
