LMS 3.2.1 - ANIServer / Campus Manager - Topology Services
walter_vignolo
Hi.
I´m having some problems to use the Topology Service.
I receive the following message:
I made an entry in the HOSTS file (c:\WINDOWS\system32\drivers\etc), but It doesn´t work:
How can I solve the problem ?
Thanks.
16 Replies 16
You should turn the Java console off now.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi again
I Think I've found out how I solved the problem.
From another thread I've read about the "ANIServer.proberties"-file. I found it and discovered that it only contained one line:
"PurgeArchivesOlderThan=180EnablePurgeJobs=ONPurgeJobsOlderThan=180EnablePurgeArchives=ON".
In the same library I found the default proberties  -file "ANIServer.properties.orig", which I used to replace the current  one. After editing the "DEVICESROOT"-path and restarting the server,  everything started working again.
