LMS 3.2.1 - Config Job with Varying Parameters per Device
Brian Saunders
Hello all,
Have a question in regards to deploying a job either within NetConfig or Compliance Management via Ciscoworks LMS 3.2.1.  Basically we are wanting to deploy an access-list to all our devices, example:
ip access-list 10 deny host 192.x.x.15
ip access-list 10 permit any
The 2nd and 3rd octets in the IP address of the deny statement would be unique to each device that we deploy the job to.  I have read that this is possible via a parameterized file BUT would each device and the deny IP address specific to that device have to be defined within the XML file?
Cheers,
Brian
Brian Saunders
So just want to confirm - the only way I can do this is if I create a NetConfig job that has the parameterized box checked off and setup like so:
access-list 10 deny host $device
int tunnel 0
ip access-group 10 out
exit
int tunnel 11
exit
And then drop an XML file on the server that defines each device and the IP address that is unique to each device like so:
10.1.1.34
10.2.1.34
Just want to make sure there isn't another method that wouldn't require creating an XML file that defines every device we need to update.
Cheers,
Brian
