Bookmark
Subscribe
783
LMS 3.2 Adding Devices Manually
Erick.Valle
Can anyone tell me if I need a seed devices to add devices manually or can I just bypass this portion of the setup since I'm NOT going to be discovering anything with Ciscoworks.(My envoronment is to complex to perform and discovering)  Or do I need a seed device anyhow for functionality of Ciscoworks and other processes?
Please advaise & thank you in advance,
Erick
Nael Mohammad
Level 5
Level 5
If you are adding devices manually, there is no need for a seed device. The whole purpose of seed devices is to use it as staging for discovering neighboring devices.
There is a great document written on the CSDiscovery process in LMS by Joe.
https://supportforums.cisco.com/docs/DOC-9005
Thanks Nael, Your answer is sufficient. The document by Joe is good and I have reviewed it in detialed by it does not reference anything about my question, but he does go over everything else in the discovery section of the install.
Thanks for your time.
Erick
