12-15-2010 12:20 AM
We have noticed that our LMS is affected by this bug. If you see the bug details
there isn't workaround. Can I fix it without to upgrate to lms v4?
Solved! Go to Solution.
12-15-2010 12:30 AM
yes there is a patch,
you need to open a TAC case so they can provide it.
12-15-2010 12:30 AM
12-15-2010 12:40 AM
thank you Fadi
