LMS 3.2 and MS SCOM and SCCM
smandrapa
Is there any recommendation regarding installation of CW LMS 3.2 and MS SCOM and SCCM on the same server?
Joe Clarke
This was not tested internally, so I cannot say whether or not there are any conflicts or problems.  If possible, consider virtualizing LMS on one VM with the MS managers on another VM.  Provided resources on the hardware are sufficient, this would be the safest course if all suites need to be on the same physical server.
