LMS 3.2 Compliance Template syntax help
barkerc123c
I want to add the command "no logging event link-status" to all switchport mode access ports EXCEPT for the ones with the following switchport access vlans: 4022,4032,4042,4052,4072 & 4082. How do I create a compliance template to do this?
LMS 3.2, RME 4.3.1
Try this pattern for the prereq:
+ switchport access vlan [#(?!(4022|4032|4042|4052|4072|4082)).*#]
6 Replies 6
Joe Clarke
Try this:
IsPrereq: Yes
Sub-mode: interface [#(Fast|Gigabit)Ethernet#]
Body:
+ switchport access vlan [#(?!(4022|4032|4042|4052|4072|4082))#]
Prereq: VlanPrereq
Parent: VlanPrereq
Body:
+ no logging event link-status
Tried it & it didn't work. Here is a sample config of the ports. Command should not deploy on ports fa1 & 3 & gi1 but should deploy on fa2,4-8.
interface FastEthernet0/1
description NetOps Data/VoIP
switchport access vlan 4082
switchport nonegotiate
switchport voice vlan 4083
snmp trap mac-notification change added
spanning-tree portfast
ip dhcp snooping trust
interface FastEthernet0/2
switchport access vlan 661
interface FastEthernet0/3
switchport mode trunk
spanning-tree portfast trunk
spanning-tree bpduguard disable
interface FastEthernet0/4
ip access-group POLICY in
authentication order dot1x mab webauth
authentication port-control auto
authentication fallback WEB_AUTH_PROFILE
mab
no snmp trap link-status
dot1x pae authenticator
dot1x timeout tx-period 5
no lldp transmit
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
description VoIP Phone 43170
interface FastEthernet0/8
description Docking Station
interface GigabitEthernet0/1
description Feed from c3750uhs011a fa3/0/30
rmon collection history 10101 owner campusmanager buckets 10 interval 300
Sorry, typo:
IsPrereq: Yes
Sub-mode: interface [#(Fast|Gigabit)Ethernet.*#]
Body:
Prereq: VlanPrereq
Parent: VlanPrereq
Body:
Now I get CM0152 Prerequisite Commands does not exist in device archive
That did it! Thank you!!!
