LMS 3.2 DFM email notification problem
I got a problem in a newly installed LMS 3.2 with the DFM email notification.
I can see the alerts appering on Alerts&Activities, but DFM would not send any emails.
I can get emails from other moduls of LMS. CS sends me emails from successfully backups.
The SNMP Server works fine. The settings are ok.
I already reinstalled DFM.
I have seen a thread exists on supportforum.cisco.com with the same problem.
(https://supportforums.cisco.com/message/3033101#3033101)
Maybe anyone have the answer to this problem.
C8-Netzwerk
Michel Hegeraat
Level 7
Level 7
DFM has its own SMTP Server configuration not related to the one from common services that send your backup mail
But I guess you entered the correct server in the subscription
Not sure what the exceptions in you log mean though. Doesn't look good.
Cheers,
Michel
Yes, I entered the same(correct) smtp server address in DFM notification services.
thanks for your reply
Joe Clarke
This looks like an issue I am currently tracking.  I have written a patch which should correct this.  You can get the patch by opening a TAC service request, and having your engineer contact me directly.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
