11-27-2009 11:35 PM
Dear friends,
I am having a problem with discovery on Ciscoworks LMS 3.2. The discovery process runs eternally and does not discover any devices.
Here are the individual device versions:
Name Version Size Status Expiration Date
1. CM 5.2 300 Purchased Never
2. DFM 3.2 300 Purchased Never
3. HUM 1.0 100 Evaluation Sun Jul 26 12:18:01 GMT+03:00 2009
4. IPM 4.2 300 Purchased Never
5. RME 4.3 300 Purchased Never
6. VNM 1.0 Unlimited Purchased Never
Please find enclosed the csdiscovery.log which indicates the following error
1000 [main] DEBUG com.cisco.nm.csdiscovery.CSDiscoveryManager - FATAL: Exception occured in the start discovery Exception occured during start of discovery in CS.
Reason : failed to initialize DiscoveryController
I am also enclosing the CSDiscovery-config.xml under the config directory and the specific job as well.
ngdiscovery.log shows 0 bytes. I am not sure if it is to be populated only when we initiate some debugging?
Thanks a lot
Gautam
11-28-2009 08:45 AM
It seems you're missing some critical files. Under NMSROOT/conf/csdiscovery, you should have the following zip files:
SharedDiscoveryAUS.zip
SharedDiscoveryCluster.zip
SharedDiscoveryGeneral.zip
SharedDiscoveryIGX.zip
The casusers group should have full control on all four files. If these files really are missing, you will need to contact TAC to get new ones, or you will need to reinstall Common Services.
11-28-2009 08:55 AM
Dear Jason,
I do have all the four files and the casusers does have full control over these four files under C:\Program Files (x86)\CSCOpx\conf\csdiscovery directory.
Thanks a lot
Gautam
11-28-2009 09:10 AM
11-28-2009 09:23 AM
Dear Jason,
I have started the discovery now and it seems to be running as before.
But when i click on Start discovery button in Discovery settings, it should change to Stop Discovery, right?
But it does not change to Stop Discovery.
I still seem to see the same symptoms.
Thanks a lot
Gautam
11-29-2009 12:21 PM
Jason,
I am also closing this thread with the same resolution: reinstall fixed everything!!
Thanks a lot
Gautam
