LMS 3.2 in solaris
mpbala_pisces
We  are using LMS 3.2 in Sun platform.In which directory LMS archiving the  configuration files of all the routers,under shadow directory i am able  to find few routers configuration and also i need to have date wise  configuration.Through GUI in version tree am able to find the  configuration.
I enabled data collection one day once.
Please guide me for this
Regards,Bala
AFROJ AHMAD
Hi Bala,
Yes you are right the Location of the backup configuration files on solaris is:
On Solaris, /var/adm/CSCOpx/files/rme/dcma/shadow
In this location as soon as cisco works found a change in your device configuration it will backup the configuration file in this location itself.
Configuration backup is not a part of DataCollection.
You need to configure the SYNC-ARCHIVE job  (RME > config mgmt ) for archive collection \ configuration backup.
I hope this will help..
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
