LMS 3.2 Logrot - Limitation on number of rotations?
William Hahnel
I have LMS3.2 running and have set up daily log rotation of my SYSLOG file via Common Services-Server-Admin-Log Rotation.  In LMS2.6 I set this up from the command line and was able to set the number of rotations to 120.  I found in LMS3.2 setting up the rotation via the GUI that the number of rotations is limited to 90.
Is there a way to up this limit??
Thanks for your help!
Thomas Masters
I would say use the CLI version of the command and see if you can enter 120 there.
> cd NMSROOT\bin
> perl logrot.pl -c
Option 2 to Edit log files
