Hi Ricardo,
Note: Be careful while you access the DBREADER. if you have any doubt , you can open TAC case to follow the below steps..
You need to go to the dbreader(database) to delete the syslogs tables and put the following in the AD-hoc page:
http://<hostname/ip address>:1741/dbreader/dbreader.html
or
https://<hostname/ip address>:443/dbreader/dbreader.html
User Id: DBA
Password: rmeng db password (default is C2kY2k)
Database Name: rmeng
And click the get tables button.
In the tables look for the SYSLOG_* type of tables and note their names.
example:
SYSLOG_20090631
SYSLOG_20090701
Then go back to the Ad-hoc page and issue the following sql statement:
DROP TABLE SYSLOG_20090701
Delete all the SYSLOG_ files and then issue the below command on the ciscoworks server:
then you need to re-run the DBSPACERECLAIMER script.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
