LMS 3.2 Veritas HA requirements question
jabeck018
In the Install document, for Windows Install, the Veritas HA solution says it only supports 32-bit Windows OS and Windows 2003.  I see the document was written in May and I was wondering if it will support 64-bit Windows 2008 now?  Also, will 4.0 support Windows 2008 64-bit using the Veritas HA solution?  I am wondering if this document is saying it won't work or just that it is untested.  This is the document I am looking at:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/lmsig.pdf
Joe Clarke
Only 32-bit will work with LMS 3.2.  I have not heard definitively if 64-bit is being added for 4.0, but my understanding is there were not many changes in the HA space.  You may want to consider the VMWare/VMotion alternative for HA as it will support 64-bit Windows 2003 and 2008.
