LMS 3.2
rnieuwhof
I am experiencing an issue in LMS 3.2 where devices in the DCR, are being managed in RME, and cannot be discovered in DFM.  I have applied all known updates, Turned off auto-discovery, then re-started LMS.  Then re-enabled Auto Discovery.  No Change.  Where should I go next?
CS - 3.2.0
CM - 5.1.4
CV - 6.1.8
CW Asst - 1.1.0
DFM 3.1.3
IPM - 4.1.0
Integ Util - 1.8.0
LMS Port - 1.1.0
RME - 4.2.0
Assistance appreciated.
Rob
Joe Clarke
The versions you are listing are for LMS 3.1, not 3.2.  When you say that the devices are not being discovered, do you mean they are going into a Questioned state?
