Bookmark
Subscribe
550
LMS 3.3 no add device in DCR
hmaparicio
I have installed the LMS 3.2, and when i add devices in Device Management, with its credentials, but it doesn't show this devices in teh DCR.
I create a dicovery and it show a message that the device is unreachable. From this server i can do a tTlnet, ping and SNMP.
Best regards,
     Hugo
Fadi Twal
since the device is showing unreachable from the discovery output then that means the SNMP operation didn't run fine.
so you may try to increase the SNMP timeout and re-tries from the discovery settings.
also try to use a sniffer trace while doing the discovery and see the response from the device to the SNMP.
