Showing results forĀ
Search instead forĀ
Did you mean:Ā
LMS 4.0.1, changing device credentials.
andrea.meconi
Level 2
Level 2
Hello.
I need to edit device information for multiple devices  using feature Edit Credentials. I'm not able to overwrite all device credentials using a new set.
Any idea?
Thanks.
Andrea
Martin Ermel
you have to create the Credential Set first before using it; this is done in:
     Admin > Network: Device Credential Settings > Default Credential Sets
after that, when you have selected the devices to edit and you click on "Edit Credentials" - have you noticed the options below the drop-down box? These options are available
    - Overwrite All Device Credentials
    - Apply Only Missing Device Credentials
and you have to choose the first (the second is default)
Now, all credentials in the choosen credential set will be applied to the selected devices (without verification of the credentials)
Hello Martin and many thanks for your help.
You are right but this prodecure does not work. I can test it successfully with LMS 3.2.
Any idea?
Regards.
Andrea
