LMS 4.0.1 DFM View
fbender
this is a newbie question. I see in the overview fault counter of 8, when I click on it I get to the "Fault View" and see no faults. In Device Fault Summary I see critcal counters for some devices but whern I click on the device I see no critical faults. Where do I see these faults?
Frank
There is a doc from cisco's Joe Clarke on the forum.
https://supportforums.cisco.com/docs/DOC-8796
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
I normally add a nwpass= to also set the databases to te password I use for all other databases but if you haven't changed it during install then this is optional
Michel Hegeraat
Level 7
Level 7
I was tolled to clear the fault management databases when I had this issue.
While this does resolve the issue it does not prevent it from comming back.
Also I noticed it goes away by itself.....circumstances unclear....
Cheers,
Michel
Hi Michel,
thanks for the answer!
Do you know how to "clear the fault management databases"? Is there a white paper?
Cheers
Frank
