I need a help:
I installed the Cisco LMS 4.0.1 (test mode), and monitoring services of the switches (data collection and information system) are working.
But when I need to apply some configuration via CiscoView settings are not applied.
The following message is displayed when I try to apply some configuration on an interface of any one switch.
Message
Timeout on 172.20.1.10.
This error could be due to lack of access to the host, invalid SNMP credentials, or a busy device.
To correct the problem, do one of the following:
- Verify access to the host.
- Check the SNMP credentials.
- Increase the timeout value through the preference options on the chassis view."
I've checked the credentials and SNMP communities, the problem continues.
Any idea?
Tks!
Marcos
