LMS 4.0.1 : Workflow VLAN assignment issue on VSS and 3750
I'm running on LMS 4.0.1 with latest update and upgrade package (not the lms 4.1).
I have : VSS running on 12.2(33)SXJ1
and 3750x running on 12.2(58)SE2
When I try to perform some VLAN Port assignment change, I cannot do it through the Workflow :
Config > Workflow > VLAN > Config port assignment
When I click on the VSS and then "List ports", the list of the ports is clear ! The VLAN list is correct.
When I click on the 3750 and then "List ports", the list of the ports is complete, BUT the VLAN list is incorrect, with this kind of VLAN list :
"inactive1 NULL"
"inactive101 NULL"
"inactive2 NULL"
What could be the problem ?
By which way can I easy change port vlan assignment and see what's the port status at the same moment ?
By the way, in CiscoView : is it also normal that I cannot change configuration of port that are not wired-connected on the switches ? Gi1/0/10 is connected and I can change POE, etc...but the Gi1/0/5 is not plugged and I have only physical information of the link.
Thank you for your help
Is there anybody encountered the problem ?
