Hello. When I change configuration for the ASA device with LMS 4.0 Configuration-->Tools-->Config Editor, the configuratin changed, but the job fails with the Error:
Deploy command partially failed TELNET: Failed to establish TELNET connection to 172.25.5.193 - Cause: connect timed out. Primary Login Succeded / Primary Enable Succeded Insufficient no. of interactive responses(or timeout) for command: ip address 172.25.5.193 255.255.255.0.
The Telnet protocol is disabled..The parameters in the cmdsvc.properties files are:
# max timeout value for waiting for login prompt from a device(in ms)
LoginTimeout=2000
# Sets the initial value of the socket timeout while doing login (in ms)
#InitialTransportTimeout=5000
# Set the timeout value of the transport. This usually corresponds to the socket's timeout value.(in ms)
#TransportTimeout=45000
# Set the delay to sleep before proceeding.(in ms)
TuneSleepMillis=1500
# Set delay after creating socket and before doing any communication.(in ms)
#DelayAfterConnect=300
# Set delay between read process (in ms)
#ReadDelay=10
How can I fixed this error. Thank you and best regards.
