LMS 4.0 Device Credentials Verification report
jesper_fr
I have a problem when doing this report. If I do a device credentials report on a user defined group (40 devices) 11 of these devices
fails to connect via SSH. I can make an SSH connection to all 11 devices from the CiscoWorks server, but 11 devices still fails on the report
    Device Name     Read Community   Read Write Community            SSH
1. 149.212.XXX.164      Ok                          Ok                         Failed to connect.
2. 149.212.XXX.153      Ok                          Ok                         Failed to connect.
3. 149.212.XXX.152      Ok                          Ok                         Failed to connect.
4. 149.212.XXX.151      Ok                          Ok                         Failed to connect.
5. 149.212.XXX.150      Ok                          Ok                         Failed to connect.
6. 149.212.XXX.149      Ok                          Ok                         Failed to connect.
7. 149.212.XXX.140      Ok                          Ok                         Failed to connect.
8. 149.212.XXX.139      Ok                          Ok                         Failed to connect.
9. 149.212.XXX.138      Ok                          Ok                         Failed to connect.
10. 149.212.XXX.130     Ok                          Ok                        Failed to connect.
11. 149.212.XXX.129     Ok                          Ok                        Failed to connect.
oemoralesjr
I have the same problem.  Anyone seen this and resolved this issue?
I actually found out what the problem was. It was wrong SSH version. I had several switches of the same model. All of them was using SSH version 2, but for an unknown reason SSH version was wrong for some of the switches. Try setting SSH version to version 1 and the back to version 2. If you debug SSH connection to the switch you will see that SSh version is wrong
Rgds,
Jesper
