LMS 4.0 Fault Management Module alert doesn't show CurrentUtilization
I would like to know if there's a way to show CurrentUtilization percentage within the messages generated by the Fault Management Module in LMS 4.0
EVENT ID                = 00008Z1
TIME                    = S
STATUS                  = Active
SEVERITY                = Critical
MANAGED OBJECT          = switch
MANAGED OBJECT TYPE     = Switches and Hubs
EVENT DESCRIPTION       = HighUtilization::Component=PORT-switch/11150 [Gi3/0/50] [---> TRUNK ];ComponentClass=Port;ComponentEventCode=1057;TrafficRate=5.2261432E7  BYPS;DuplexMode=FULLDUPLEX;UtilizationThreshold=40;MaxSpeed=1000000000;Type
NOTIFICATION ORIGINATOR = Fault Management Module
As you can see above CurrentUtilization percentage is not shown in Event Description section.
Could someone help?
Thank you!
Massimiliano.
Michel Hegeraat
Level 7
Level 7
To my knowledge nothing can be configured here.
You have to take traffic rate and max speed and do the calculation yourself
FAD! functioning as designed
Cheers,
Michel
Hi Michel,
thanks for your reply. It was my suspicious!
Maybe someone else can enlighten us.
Or at least let us know  if the CurrentUtilization percentage counter will come with  future  release/patch.
Ciao,
Massimiliano
