LMS 4.0 Installation errors on Solaris
p.woudstra
Can somebody please help / advice us concerning the installation of CW LMS 4.0.1 on Solaris 10!
The installation keeps on failing when it is checking for packages. Also the second time when we downloaded the software once more.
ERROR: AddProperty called with invalid package name: CSCOmd.
I have also attached the install log files.
If someone has an idea?
Thanks in advance.
Regards, Patrick
The system is Solaris 10 with zones:
bash-3.00# more /etc/release
                      Solaris 10 10/09 s10s_u8wos_08a SPARC
           Copyright 2009 Sun Microsystems, Inc.  All Rights Reserved.
                        Use is subject to license terms.
                           Assembled 16 September 2009
bash-3.00#
bash-3.00# showrev -p | grep -i 122032-05
Patch: 141518-04 Obsoletes: 122032-05, 125378-05, 128300-04, 138856-02, 139966-05 Requires:  Incompatibles:  Packages: SUNWcsu
Patch: 141518-11 Obsoletes: 122032-05, 125378-05, 128300-04, 138856-02, 139966-05 Requires:  Incompatibles:  Packages: SUNWcsu
bash-3.00#
bash-3.00# showrev -p | grep -i 127127-11
Patch: 137137-09 Obsoletes: 120741-01, 120986-12, 120992-02, 121008-02, 121274-01, 121414-01, 122029-01, 122083-02, 122172-06, 122174-03, 122356-01, 122358-01, 122517-04, 122525-03, 123186-03, 123809-02, 123932-02, 124999-01, 125416-06, 126133-04, 126145-01, 126304-01, 126653-01, 126661-02, 126674-01, 127714-03, 127735-02, 127739-03, 127866-05, 127868-01, 127886-06, 127888-11, 127892-06, 127914-01, 127959-02, 127968-01, 127970-01, 128294-02, 128400-05, 128408-01, 128410-01, 128413-01, 128493-01, 128548-08, 136885-04, 137042-01, 137045-01, 137050-01, 137086-01, 137091-01, 137099-01, 137109-01, 137111-08, 137119-01, 137127-01, 137135-01, 137139-01, 137280-02, 137287-01, 138042-05, 138048-05, 138050-01, 138051-01, 138052-01, 138054-01, 138056-02, 138060-04, 138064-03, 138066-01, 138068-01, 138070-03, 138072-02, 138074-01, 138075-02, 138108-01, 138125-01, 138127-01, 138225-02, 138229-02, 138233-01, 138237-01, 138243-02, 138249-01, 138251-01, 138257-01, 138259-01, 138265-01, 138271-04, 138273-01, 138277-01, 138279-01, 138280-01, 138284-04, 138305-01, 138306-01, 138308-02, 138310-01, 138312-01, 138314-01, 138315-01, 138316-01, 138363-01, 138365-01, 138379-01, 138390-02, 138394-01, 138401-01, 138899-01 Requires: 118731-01, 118822-24, 118833-36, 118918-24, 119254-58, 119374-09, 119578-30, 120011-14, 120900-04, 121133-02, 125503-02, 126897-02, 127127-11, 127755-01, 138866-01 Incompatibles:
5 Replies 5
ngoldwat
Level 4
Level 4
Along with the required patches the minimum system level must be 11/06 release or higher.
Thanks.
Thanks for your reply, during preparation we checked the requirements:
LMS 4.0 supports the following Solaris 10 releases:
•Solaris 10, 10/09 release
•Solaris 10, 05/09 release
•Solaris 10, 10/08 release
•Solaris 10, 05/08 release
•Solaris 10, 08/07 release
•Solaris 10, 11/06 release
We have release 10/09 installed with the two required patches.
But I just checked and another doc states:
•Required Server Patches are 122032-05 and 127127-11
•Minimum system level must be 11/06 release or higher.
Thanks again and will try it with the 11/06 level.
Reg, Patrick
Just checked the requirements, but the 11/06 is from 2006. What we currently have is the 11/09 from 2009.
So this shouldn't be a problem as is states 11/06 or higher.
The  issue is within the software package which we downloaded twice and  copied in binary mode. But we keep on getting the same errors:
pkgparam: ERROR: unable to locate parameter information for "CSCOmd"
pkgadd: ERROR: bad entry read in contents file
Regards, Patrick
Have you verified the checksum?
3c4394820e4d2465d53a84b33f3b2f23
Yesterday we downloaded the trial version, copied it in binary mode to the new server.
This morning we did the installation and there were no issues anymore. Also restored the backup from 3.2 and upgraded to 4.0.1.
Thanks for your time and effort!
Regards, Patrick
