How to suppress some IOS syslog events with ESM
zheka_pefti
Level 2
Level 2
Hello folks,
I've been advised to look for help here at NetPro forum by Cisco TAC engineers.
This is the situation here with 80+ customer routers. They have two VLANs behind the router at every location/site and practically identical setup for hosts at each site. These hosts generate a lot of traffic that is blocked/denied by routers and we don’t want to see syslog events created after this traffic.
I have created one message discriminator that suppresses syslog from generating an event when the traffic from a particular host is dropped by the router.
This is how it looks:
logging discriminator STOP-POS msg-body drops 10.43.66.100
logging buffered discriminator STOP-POS 256000
logging host 192.168.14.4 discriminator STOP-POS
logging host 192.168.14.5 discriminator STOP-POS
Now I want to add more discriminators to filter at least two more events, e.g. I don’t want to collect events when the router drops broadcasts
101511: .Aug 30 23:10:48.737: %SEC-6-IPACCESSLOGP: list vl3-in denied udp 10.5.35.200(137) -> 10.5.35.255(137), 43 packets
101512: .Aug 30 23:10:48.737: %SEC-6-IPACCESSLOGP: list vl3-in denied udp 10.5.35.200(138) -> 10.5.35.255(138), 10 packets
101513: .Aug 30 23:10:48.737: %SEC-6-IPACCESSLOGP: list vl3-in denied udp 10.5.35.145(138) -> 10.5.35.255(138), 19 packets
I tried to create two more discriminator  as follows
logging discriminator UDP137 msg-body drops 255(137)
logging discriminator UDP138 msg-body drops 255(138)
but I couldn’t apply them to both buffered and trap logging as according to the TAC router and switching team IOS is limited with only one discriminator. They told me that I have to address it EEM team (I thought that Cisco calls it Embedded Syslog Manager) by the way.
So, I’d appreciate if you please help me create a filter that will address the above said requirements
2 Accepted Solutions
Spacing is very important.  You cannot have any spaces.
These are regular expressions.  The '.' means match any character.  The parenthesis is a special character in regexular expressions that means to group matches.
14 Replies 14
Dan Frey
ESM file to filter the message but allow others, add this file to flash.
if { $::facility == "SEC" && $::mnemonic == "IPACCESSLOGP" }  {
return ""
     } else   {
     return "$::orig_msg"
In IOS add:
C1811(config)#logging filter flash:esm.tcl
C1811(config)#logging host 10.1.1.1 filtered
- Dan
Thank you, Dan.
How would I define the string in the event that I want to drop/suppress?
Eugene
return ""  # This is will drop messages that match the facility and mnemonic of the syslog message.
     } else   {
     return "$::orig_msg" # All other messages will be sent.
Hope this helps.
Dan
If you copy and paste this example, you'll want to do:
    return ""  ; # This is will drop messages that match the facility and mnemonic of the syslog message.
} else   {
    return "$::orig_msg" ; # All other messages will be sent.
I might misunderstand the logic behind this code. And moreover I may have described the task not correctly. I don't want to drop all syslog events relating to %SEC-6-IPACCESSLOGP category. The client still wants to monitor other traffic that is denied by their ACL and I fear that if the condition is "$::facility == "SEC" && $::mnemonic == "IPACCESSLOGP" then everything will be dropped. All they need is to have the logging level set to "informational" but be able to drop broadcasts and few confirmed events.
Yes, the code will drop all syslogs with facility SEC and mnemonic IPACCESSLOGP.  However, the logic will be the same.  You may need to match on other parameters, though.  If you want to look for something in the body of your message, use $::orig_msg.  For example:
if { [regexp {10.1.1.255} $::orig_msg] } {
    return ""
This would get wrapped in that previous check for facility and mnemonic.
To escalate the severity of a message, you can use this filter script:
if { [info exists ::cli_args] } {
    set args [split $::cli_args]
    if { [ string compare -nocase [lindex $args 0] $::mnemonic ] == 0 } {
        set ::severity [lindex $args 1]
        set sev_index [ string first [lindex $args 0] $::orig_msg ]
        if {  $sev_index >= 2 } {
            incr sev_index -2
            return [string replace $::orig_msg $sev_index $sev_index \
                [lindex $args 1]]
return $::orig_msg
You need to register it with two CLI arguments:
logging filter flash:escalate.tcl args IPACCESSLOGP 5
Note: if you'd rather use logging discriminators to filter your message, you can do that.  Try something like:
logging discriminator UDPBCAST msg-body drops 255.137.|255.138.
Thanks, Joseph,
I'd rather stick to discriminators as they are easy to be understood by the customer IT stuff. I'll try to do it and get back to you. I think I already tried piping but I might have included a redundant space between the pipe and the digit and the IOS complained about it.
Eugene
Made again the discriminator with the pipe and strings without spaces. Something still is missing. Broadcast events are still logged. Below is the output of "show logging" on one of the routers. I think we can't break the IP address to match the way I did - 10.43.66.100|.255(137)|.255(138)
535_OTTAWAMARKET(config)#do sh logging
Syslog logging: enabled (0 messages dropped, 997 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
Active Message Discriminator:
LOG-FLTR  msg-body       drops    10.43.66.100|.255(137)|.255(138)
No Inactive Message Discriminator.
Console logging: level errors, 122 messages logged, xml disabled,
filtering disabled
Monitor logging: level errors, 0 messages logged, xml disabled,
filtering disabled
Buffer logging:  level debugging, 13 messages logged, xml disabled,
filtering disabled, discriminator(LOG-FLTR),
0 messages rate-limited, 1171 messages dropped-by-MD
Logging Exception size (4096 bytes)
Count and timestamp logging messages: enabled
Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
Trap logging: level informational, 112934 message lines logged
Logging to 192.168.14.4  (udp port 514,  audit disabled,
authentication disabled, encryption disabled, link up),
11 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering enabled, discriminator (LOG-FLTR)
Logging to 192.168.14.5  (udp port 514,  audit disabled,
Log Buffer (256000 bytes):
112931: .Sep  6 07:16:26.150: %SEC-6-IPACCESSLOGP: list vl3-in denied tcp 10.5.35.200(2553) -> 64.94.18.139(443), 1 packet
112932: .Sep  6 07:16:43.001: %URLF-4-SITE_BLOCKED: Access denied for the site 'updateservice.sonic.com', client 10.5.35.44:4328 server 144.198.28.150:80
112933: .Sep  6 07:16:46.034: %SEC-6-IPACCESSLOGP: list vl3-in denied udp 10.5.35.200(138) -> 10.5.35.255(138), 1 packet
112934: .Sep  6 07:17:46.035: %SEC-6-IPACCESSLOGP: list vl3-in denied udp 10.5.35.200(137) -> 10.5.35.255(137), 12 packets
You want:
logging discriminator LOG-FLTR msg-body drops 10.43.66.100|.255.137.|.255.138.
Do not use parentheses.
Even though 137 and 138 are port numbers and they are showing with parentheses in the event ?
Thanks, Joseph,
I didn't realize that we have to match based on regex. I thought it should an exact or partical match from the event string. Anyways, it seems to be working. Thanks again.
